Download @ avedesk.philc.ca (~93 KB)
Please, note (online readme):
1) This is a very rough approach to sound volume regulator. Though it works, it uses a very dirty way to set your system sound volume. This is not dangerous in any way, but you might not like this. I'll change the way I do it as soon as I learn more of Windows MultiMedia subsystem.
2) HOW TO MOVE THIS DESKLET ACROSS YOUR DESKTOP? Because of trackbar implemented you are not able to just drag this desklet. To move it, hold the Ctrl key and drag.
3) This is a direct port of Dashboard widget with the same name made by Natan Heagy. I was pretty intoxicated with this fascinating idea and asked for a permission to port it. And - guess what? - I've got it! Natan kindly permitted me to use the original graphics from his widget. I had to cut and paste a bit, but current version should look quite the same as its Dashboard brother.
4) Your ratings at AveDesk site are HIGHLY APPRECIATED and ANTICIPATED! Please look for textual link with the words "Rate Resource" beneath the desklet information and USE IT!
Have a nice volume!
Sign In »
Register Now!
Help
MultiQuote
