[help] FlyakiteOSX will not install
#2
Posted 21 January 2006 - 05:51 AM
check if you have the good Windows.. XP.. XP pack2.. etc..
and so.. have you enough memories for.. what processor?
And finally check here .. he have some thread for Flyakite here, if you have serious probs
http://www.aqua-soft.org/board/showthread....ght=FlyakiteOSX
#4
Posted 22 January 2006 - 04:50 PM
There is a VERY rare problem where it won't install on some machines. It is due to one of the plugins in the installer that executes a command line app. For some reason, on some systems the installer can't retrieve the exit code, and therefore it won't continue on to the next item. In the update, I've changed to a different plugin and it works fine, because I tested it on a friends machine who had the exact same problem.
#5
Posted 23 January 2006 - 08:46 PM
Where can I get this update? I tried downloading from the different mirror sites and each of these stops durning the install process.
Sign In »
Register Now!
Help
MultiQuote
