Flyakite 3.0 hotkey problem
2
18-January 06
Posted 18 January 2006 - 08:44 PM
Hey everyone,
This new 3.0. looks just great and I'd love to upgrade from 2.0. However....
I can't use the new one merely for one thing: something of this package is using RIGHT ALT+C
key combination which is reserved for Polish (programmers) keyboard and nowa I don't have one of my national characters. I can't figure out which part of the package is causing this. Maybe there are more such reserved key mappings. Anyway, this one is very hard to live with.
Anyone knows a workaround?
frY
Developers
886
19-November 02
Posted 18 January 2006 - 11:31 PM
My guess is that it is one of the applications included with FlyakiteOSX. First I would try shutting down the extra programs 1 at a time. Y'z Shadow. SearchSpy. ObjectDock or RK Launcher. WinRoll. And Alt+Q HotKey Tool (needs to be quit from the Task Manager).
If none of those solves the problem, then try uninstalling shell32.dll. If that doesn't work, then the rest of the system files. Do it bit by bit, and see if you can narrow down what portion is causing the problem. If you figure out a major section, then install it smaller bits at a time, like half of the DLL section etc.
While its a little tedious, its the only way to narrow down exactly what is causing the problem, so that I can hopefully come up with a fix/workaround.
Administrators
7,909
26-February 04
Posted 19 January 2006 - 12:21 AM
What happens when you press Right + Alt + C? That would help narrow down what app is stealing this keystroke...
2
18-January 06
Posted 19 January 2006 - 12:47 AM
Thanks flyakite, I'll give it a go after work. Thought you might know an answer right away.
What I think it isn't the fault of any app. Tried turning off all of them in the registry and the problem remained. The point is when you ALT-C - nothing happens. Otherwise, I would have tracked the app right away. :/
Talk to you soon.
fry
btw. Is there any smart little soft that allows you to check what is responding to a given key combination?
