Aqua-Soft Forums: Increasing Yz/Mb Speed on Slow Comp's - Aqua-Soft Forums
Increasing Yz/Mb Speed on Slow Comp's Rate Topic: -----
#1 User is offline   Taha Icon
Posted 09 November 2002 - 08:40 PM
Ok, first of all go to taskmanager. Right click yzdock/mobydock and set its priority to "Above Normal". Run a Ram-defragging utility to improve overall + dock speed, something likeHare.
Hope this helps!
Oh, I forgot to mention how happy I am that Aqua-soft is back up. Hope it stays up this time.. :lol:
#2 User is offline   siddharth Icon
Posted 09 November 2002 - 10:54 PM
Hi there Taha (tahaumer..that's you right??) nice to see you here. thanks for the tip...the priority tweak really speeded things up..
siddharth
#3 User is offline   Taha Icon
Posted 10 November 2002 - 03:28 AM
you're welcome.
yup...its me alright :D
#4 User is offline   bsiple Icon
Posted 10 November 2002 - 04:36 AM
Thank you for the tips.. they noticably increased y'z speed.. :D
#5 User is offline   Zoggynog Icon
Posted 10 November 2002 - 08:49 PM
It might just be my outdated 700mhz Duron...but when I did that I noticed problems playing my music through Kazaa. If I was playing an mp3 and moved the cursor over Y'z it would make the song skip. Just thought I'd throw that info out there and see if any of you experienced the same thing, or maybe a way to fix that problem.
#6 User is offline   smeggy Icon
Posted 10 November 2002 - 10:46 PM
Yeah, messing with priorities can be both a good and bad thing depending on how the apps all interact. One solution I found is useful is to get a commercial app like 'PriorityMaster' which lets you set all the priorities of all the apps you want so they behave nicely with each other. It costs a few bucks but at least it will load everything at the priority 'you' want, rather than everything being set to Normal. Very useful little app.
#7 User is offline   ricky Icon
Posted 11 November 2002 - 05:51 PM
Is there a way to tell a program to run, by default, in a higher priority? Without using a 3rd party program?
#8 User is offline   Taha Icon
Posted 11 November 2002 - 07:24 PM
I dont think so... you can only specify for the apps that are running. But let me check.. http://www.download.com>
#9 User is offline   mguiddy Icon
Posted 12 November 2002 - 01:17 AM
I found two option
MyRun
and
Priority Launcher
MyRun uses a GUI to make files similar to .bat files. It can launch multiple programs with one file, good if you want to run multiple Y'z or Mobys etc and can change priority and can pause before and after launching.
Priority Launcher is just a cmd line app that can launch an app with a different priority.
Example( from readme.txt)
Quote
        prioritylauncher [-i|h|n|r[w]]
           options (optional) :
              i=idle (this is the default anyway)
              h=high (bad news)
              n=normal (why are you bothering?)
              r=realtime (prepare for a cold reboot)
              w=wait till loaded before setting priority
#10 User is offline   ricky Icon
Posted 12 November 2002 - 06:46 AM
exactly what i was lookin for. thanks :)
#11 User is offline   Taha Icon
Posted 12 November 2002 - 03:48 PM
Here's another Tip!!!
This one really made me v.v.v.verrry sad :(
Cursorxp slows down yzdock/mobydock! I was sooooo dissapointed since I absolutely love the OS X pack for C XP.
#12 User is offline   siddharth Icon
Posted 12 November 2002 - 08:37 PM
but why....all i can see in the CursorXP icon pack is the revolving disc..Iceman has already incorporated nice cursors into his Jaguar 2.0 Visual Style
get it at www.amilcarguerra.com/~iceman
Siddharth
#13 User is offline   Taha Icon
Posted 12 November 2002 - 08:52 PM
actually i like the cursprxp pack more because of higher (32-bit) image quality and smoother animations. Haven't checked out iceman's yet though. I'll do that now.
#14 User is offline   Goku Icon
Posted 13 November 2002 - 08:00 AM
hehe i made that crappy lil beach ball with the triangle.
i think i made a nicer pack now.. ill post it in the customizing forums in a bit.
i didnt really use cursorxp, but i remember it slowed my 3d stuff pretty bad, so i stopped using it.
thanks for the reminder tahaumer!
#15 User is offline   ricky Icon
Posted 13 November 2002 - 09:20 AM
Check out the Y's Apps forum for my new way to boost performance in Y's Dock.
#16 User is offline   Chatbox Icon
Posted 20 November 2002 - 10:03 AM
To answer the question of starting application with preset priority.
Use the "start" command (not the Start button), but the start command.
To see what is available, type "start /?" at a dos window/command prompt.
#17 User is offline   sillymnkyboyo Icon
Posted 22 November 2002 - 06:04 AM
Can someone email me Icemans' Jaguar theme for ObjectBar (New or Original version the way Ice intended)... I tried loggin into his site recently with lil' luck. Please PLease PLEASE send me that theme pack AOL accepts large file transfers through email (the only good thing about it)... chemest879@aol.com ... id really appreciate it.
-Greg :ph34r:
#18 User is offline   Genx Icon
Posted 30 November 2002 - 11:28 PM
I set my Mobe Dock and Winamp priority at AboveNormal so that my music wouldn't skip because I had that problem as well when my Mobe Dock was on and now everything seems to be running smooth, but what can I use so that the priority of Mobe Dock to stay in AboveNormal...? :unsure: :blink:
#19 User is offline   orcinus Icon
Posted 30 November 2002 - 11:44 PM
Read the 9th post on the previous page!
Orcinus
