Aqua-Soft Forums: RK Launcher problem - Aqua-Soft Forums
RK Launcher problem
#1 User is offline   jacklofi Icon
Posted 10 July 2005 - 01:20 PM
I don't know if anyone on here has had this same problem, I searched and couldn't find anything so don't bite my head off if this has been posted before.. but when I load up RK Launcher (0.2 or 0.3), it doesn't do anything, it's not visable on the screen anywhere .. then, if I check my running tasks I can see it's there, working ok. I can't seem to find any way around this problem at the moment, I've asked Larsen and he doesn't know either. Also, if I have either version of RK Launcher open, when I minimize a window to the taskbar, it disappears.. weird, I know.
Any help would be greatly appreciated.
#2 User is offline   Ellada Icon
Posted 10 July 2005 - 01:31 PM
http://www.aqua-soft...ead.php?t=23893
What makes your bug any different than everyone elses?
#3 User is offline   steelfist Icon
Posted 10 July 2005 - 02:09 PM
yep. post it in the thread called: bug report. also, was it autohiding? did you try out another refreshed out-of-the-zip-without-changing-anything launcher?
