Aqua-Soft Forums: [help] Icon quality problem - Aqua-Soft Forums
#1 User is offline   aQuestion Icon
Posted 31 May 2005 - 08:19 AM
Did anyone else notice that when you drag a shortcut to the dock, the icons look okay until you scroll over them and they magnify? The blocky look isn't pleasing, especially next to the high quality icons provided with the dock. Is there a way (a place?) to get high quality dock icons for random programs like firefox, MPC and AIM?
#2 User is offline   fmpuk Icon
Posted 31 May 2005 - 09:08 AM
You can do any of a number of things:
OSX-e offer 1000 Panther PNG's that you can use on your dock. Check that out over at www.osx-e.com
Search these forums, users have created numerous PNGs
WinCustomize is also a great resource for icons http://www.wincustomize.com/
#3 User is offline   Unbeliever Icon
Posted 31 May 2005 - 09:34 AM
umm
this is a stupid thread title, try harder next time :slant:
_______________________
/Title edited
Unbeliever
#4 User is offline   icexswipe Icon
Posted 31 May 2005 - 10:38 AM
you can convert the icons you are currently using to png and that problem will be resolved
you should use pngs
#5 User is offline   aQuestion Icon
Posted 31 May 2005 - 04:23 PM
Unbeliever said:
umm
/Title edited
Unbeliever
be nice...
#6 User is offline   aQuestion Icon
Posted 31 May 2005 - 04:57 PM
you should use pngs
I'm trying to do that with AveIconifier2 but I can't seem to find a .ico file in my AIM folder for example. And if I drag the .exe it says 1 PNG created yet both windows remain blank so nothing can be dragged out..
#7 User is offline   Unbeliever Icon
Posted 31 May 2005 - 05:07 PM
1. Do not tell me to be nice. Instead try to post threads with more logical titles
2. Do not double post. Read the forum rules for clarification
#8 User is offline   icexswipe Icon
Posted 31 May 2005 - 05:41 PM
yea i guess you should extract the icon from aim.exe with reshacker
convert ico to png and you should be good to go
the only problem is that the icon might not have larger sizes than 32x32 so it might appear blocky if the zoom on your dock goes higher...
anyways most people dont prefer default icons (atleast on windows) so you can grab one of the many replacement icons from this site and others
btw what was the thread title earlier..just curious :P
#9 User is offline   dreadnaut Icon
Posted 31 May 2005 - 05:54 PM
"random dock icons", it's still written on top of some posts :)
@aQuestion:
icons in executable files are usually small. It's unlikely to find them bigger than 48x48. There is no way to scale them and make them bigger without blurry and blocky results. There is no difference between letting the launcher get an icon from the executable and extracting/converting it to png. You have to find another, bigger, icon for your program. deviantart has a huge collection, I'm sure you'll find what you need :)
#10 User is offline   aQuestion Icon
Posted 31 May 2005 - 06:59 PM
Say what you have to say but say it like an adult, not a child. No one needs to tolerate insults on this board.
#11 User is offline   Unbeliever Icon
Posted 31 May 2005 - 08:20 PM
Exactly.
And if you try harder next time, nobody will be insulted.
Now let's get back on topic shall we?
#12 User is offline   raduking Icon
Posted 31 May 2005 - 09:18 PM
thanx Unbeliever ;)
#13 User is offline   danmarshall Icon
Posted 31 May 2005 - 11:24 PM
I do hate to sound dumb, but i can't find anywhere how to use PNG icon files after getting them. How do i use them?
#14 User is offline   hallf Icon
Posted 31 May 2005 - 11:32 PM
put them in your "icons" folder. Now when you create a dock item, right click on it to bring up it's properties. In the properties dialog you can change the icon used for the dock item. Select your PNG file you saved in the icons directory...you're done.
#15 User is offline   danmarshall Icon
Posted 31 May 2005 - 11:40 PM
thanks man, you're a life saver
#16 User is offline   raduking Icon
Posted 01 June 2005 - 12:53 AM
The icon quality problem comes from the fact that i use IExtractIcon COM interface to get the right icon
with that interface you can only extracts icons the size your explorer (shell) has set as default usually 48x48...
I could do a thing for exe files to directly get the icon via it's resources... I have to check...
#17 User is offline   ZuLuuuuuu Icon
Posted 28 July 2005 - 10:59 PM
How can I make transparent backgrounds for my custom icons with .png extensions?
Edit: Ok, I've found a tutorial which works: http://www.axialis.c...al-misc001.html
