Aqua-Soft Forums: (Help) opening 2 applications at once with one ICOn, or docklet - Aqua-Soft Forums
(Help) opening 2 applications at once with one ICOn, or docklet Rate Topic: -----
#1 User is offline   Austin123 Icon
Posted 21 April 2005 - 06:00 PM
Hello, I was just wondering if anybody has seen possible, to open 2 applications from one Dcklet or icon,
for example i like Thundeerbird but to to get my Hotmail from it i ned to open hotpop.exe,
is there a way so that when i click on the Thuderbird icon in YZ DOCK, it will open 2 applications at once thundebird and hotpop, using some sort of parameters or Arguments,
#2 User is offline   shmengie Icon
Posted 21 April 2005 - 06:15 PM
you could do this with a vbs script, drop the script on your dock, then give it a pretty picture. also, you could do the same with a bat file.
#3 User is offline   Ghostwalker Icon
Posted 21 April 2005 - 10:10 PM
I could probably throw something to gether in konfabulator
#4 User is offline   Austin123 Icon
Posted 21 April 2005 - 10:55 PM
thank you, can anybody make the VBS script for me,, since i dont know a thing about programming, thank you again
#5 User is offline   Austin123 Icon
Posted 21 April 2005 - 11:13 PM
sorry for the Offtopicness but does anybosy know why the Itunes toolbar will not show on explorer, I just dont know what happened or why it wont show
#6 User is offline   ZiUL Icon
Posted 22 April 2005 - 12:02 AM
Create a batch file and point the shortcut ot it:
@echo off
start MYAPP.EXE
start MYAPP2.EXE
exit
#7 User is offline   Austin123 Icon
Posted 22 April 2005 - 12:30 AM
thanks that opened one application, only though Thunderbird.exe, I am still having trouble with Hotpop.exe the second file i want to open, it gives me a error saying that it can't find the application however i know its there and it exists in C:Program FilesHotmail Popperhotpop.exe
any help regarding this issue
This is what i put in the batch file:
@echo off
start thunderbird.exe
start hotpop.exe
exit
Not even if I put this:
@echo off
start C:Program FilesHotmail Popperhotpop.exe
Both of those solutions only open one application, does it have something to do with the regestry
#8 User is offline   Austin123 Icon
Posted 24 April 2005 - 12:39 AM
sorry for double post, but has anybody seen my above post and think they can help me
#9 User is offline   Blitz Icon
Posted 24 April 2005 - 04:01 AM
Why dont you shorten the names to 8.3 dos?
example c:progra~1hotmai~1hotpop.exe.
