Aqua-Soft Forums: [help] Konfab installed never finishes ! - Aqua-Soft Forums
[help] Konfab installed never finishes ! Rate Topic: -----
#1 User is offline   Hobbes Icon
Posted 14 November 2004 - 09:45 PM
Hi doods.
I just downloaded konfabie for windows and the installer
hangs when its about 65 % installed. I try quiting the installer
and it gives my a stoopid window saying are u sure you wanna
quite ? so I click yes but it doesnt quit. Then if I click quit
again nothing happens. I finally just have to go to the task
manager and kill it. Has anyone had this problem before ? I
think it might be related to the MSI installer cause I remember
having this problem before with some other softeare that I cant
remember the name of right now.
Thanx in advance,
Gabriel.
#2 User is offline   aashish13 Icon
Posted 14 November 2004 - 10:09 PM
Maybe close all external apps and try. Worked for me like a charm. Maybe leave it for an hour or so will its installing. If it doesn't finish you know its the installer. Mine worked just fine. :P
#3 User is offline   nightcrawler1089 Icon
  • Group: Administrators
Posted 14 November 2004 - 10:40 PM
Seems small, but did you double click the .msi file, or right click--> Install it?
Don't know why it would matter, but it's worth a try...
#4 User is offline   Pe8er Icon
Posted 14 November 2004 - 10:46 PM
Topic moved.
We already have a Konfabulator subforum, I'm sure you are aware of that ;)
#5 User is offline   Hobbes Icon
Posted 14 November 2004 - 11:42 PM
Oh sorry pe8e didnt realize.
I tried rebooting btw and ran the installer before starting any other apps.
Same thing.
#6 User is offline   losconquistador Icon
Posted 14 November 2004 - 11:58 PM
is there a process "msiexec.exe." still running in the background after u abort the install? if so, try killing it and retry the installation
cos i recently had this problem while trying to install java :slant:
#7 User is offline   MDZ61384 Icon
Posted 15 November 2004 - 12:36 AM
try running it in safe mode and see if that works maybe?
#8 User is offline   Hobbes Icon
Posted 15 November 2004 - 09:37 AM
I have two copies of msiexec.exe (the msi installer engine isnt it ?) runnning
at the same time. I killed them both and tried again but still the same.
