Aqua-Soft Forums: Help with manually removing explorer borders please? - Aqua-Soft Forums
Help with manually removing explorer borders please? Rate Topic: -----
#1 User is offline   my left hand Icon
Posted 27 October 2004 - 04:57 AM
Hello all,
i've done a few searches but i haven't found anything that answers this specifically;
how could i remove the borders from explorer windows?
the border i'm refering to are the borders that give the default window a slightly 3d look. [im talking about microsofts classic skin].
i dont have a picture, i could show you, but i'll try to do into greater detail.
http://www.sputnikk....shots/tiger.png
bzeitler's done it here PERFECTLY.
the Desktop window visible here doesn't have any borders on the bottom and on both sides of the window. whereas if you disabled your theme and had a look at the default windows classic theme, those borders would appear.
those are the borders i'm trying to get rid off. and i wanted to know if it was possible to do it independantly instead of applying a theme?
i have the full version of windowblinds installed, if that helps.
* i realize this isn't particularly aqua related, but;
the best skinners i know are part of this community,
and i've only ever seen it done by these skinners.
thank you!
#2 User is offline   sunshine26 Icon
Posted 27 October 2004 - 08:55 AM
go in folder option( control panel>folder option>general)
and check "use classic window folder"
et voila ;-)
#3 User is offline   my left hand Icon
Posted 27 October 2004 - 10:42 AM
et voila ;-)
lol no no no, i mean like the actual borders around any window and program.
the borders are especially visible at the bottom, and left and right sides of a window.
i appreciate your attempt at helping! :)
#4 User is offline   bzeitler Icon
Posted 27 October 2004 - 11:26 AM
I was searching for a way to remove them when using "windows Classic Settings" Myself. I am not sure that there actually is a way.
THe only way I have found to make your windows borderless is by hacking shell32.dll and removing the common tasks pane from common tasks view. Thats how I got borderless windows.
bz
#5 User is offline   my left hand Icon
Posted 27 October 2004 - 04:01 PM
bz
thanks for the tip blitz! :)
i've downloaded reshacker and i'm going through the tutorial i found by typing in "hacking shell32.dll" in the search.
#6 User is offline   Hobbes Icon
Posted 27 October 2004 - 07:31 PM
Can someone plz post a link to this tutorial ? Id be interested in reading it =)
thx
