I can't see
Its probably off-screen. Open the AveDesk control panel from the system tray, you should see the desklet listed. Double-click it and change the window position.
I change the window size in AveDesk but my SysStats config just looks all messed up as a result
I change the window size in SysStats and it all looks great until I re-run AveDesk then it all looks messed up
SysStats desklets don't scale with the window size. They just use the window size to restrict how much of the desktop they occupy (they are cropped in other words). If you want to change the scale of a SysStats desklet you need to do the following (this kinda sucks but until the next release of SysStats its all you have. Plus if you are doing this to a config that uses scripts, all hell will probably break loose and you'll wish you'd never started):
- Open the Configure meters dialog from the SysStats right-click menu.
- Add a CompositeOverlay class instance to the list of overlays.
- Move all of the other overlays into it using the Move Up and Move Down buttons. Make sure you keep the order of the overlays the same.
- Set the HScale and VScale of the composite ovelay to get the size you want.
You are using an old version of SysStats. Download the latest one from DockEx. Make sure that you replace every occurrence of SysStats (for AveDesk and/or ObjectDock, but not YzDock) with the up to date one.
How do I get rid of the label?
Open the AveDesk control panel from the system tray, you should see the desklet listed there. Double-click it, switch to the Label tab and set type to No label
My weather doesn't update
Bug in SysStats, get a patch here.
The config comes with a font, but I forgot to install it, now I can't get the config to use it
If a config uses a font that isn't installed in your system it will use a substitute instead. Now you have a problem - the substitute font is saved back to the config so it'll never use the right font. This is how you fix it up:
1. Quit AveDesk.
2. Install the font.
3. Re-install the config (or just the .ini file for the config).
4. Re-start AveDesk.
I only ever see the big blue question mark
This only seems to happen on Windows 2000 and possibly machines upgraded from Windows 2000. Again: a bug. Working on it.
Sign In »
Register Now!
Help
MultiQuote
