Aqua-Soft Forums: [help] Msn Messenger Desklet - Aqua-Soft Forums
[help] Msn Messenger Desklet Rate Topic: -----
#1 User is offline   rolandx1 Icon
Posted 12 June 2004 - 05:51 PM
I downloaded MSN messenger desklet for ObjectDock to use it in AveDesk but everytime I try to add it as a desklet on AveDesk, avedesk crashes. What is wrong? I have MSN Messenger 6.2
#2 User is offline   Ghostwalker Icon
Posted 12 June 2004 - 06:10 PM
Hate to say it I use it also and you have to have windows messenger installed also.Windows messenger must have something that msn has'nt. You have to have windows messenger enabled to run in background then it will work with msn messenger.Thats the only reason I keep windows messenger.
#3 User is offline   rolandx1 Icon
Posted 12 June 2004 - 06:17 PM
Damn. I uninstalled Windows Messenger. It annoyed me so I had to get rid of it. Where can I download it again? :(
I found it. From microsoft website. It's official. I hate M$.
#4 User is offline   Ghostwalker Icon
Posted 12 June 2004 - 06:19 PM
goggle windows messenger and get it from microsoft
Here
#5 User is offline   Ghostwalker Icon
Posted 12 June 2004 - 06:23 PM
It would be nice if someone made a new docklet that didnt require windows messenger for either objectdock YzDock or Kapsules.
#6 User is offline   rolandx1 Icon
Posted 12 June 2004 - 06:57 PM
OK, now it's working. But, I don't like these icons so would like to cjange them with Mac MSN icons. How to do that? I tried on avedesk control panel to change them for every status but its not working
#7 User is offline   Ghostwalker Icon
Posted 12 June 2004 - 07:15 PM
go into your docklets folder and replace the images making sure the names stay the same online offline and so forth
#8 User is offline   Charnoke Icon
Posted 20 June 2004 - 07:54 AM
Is there anyway that the desklet shows you which one of your contacts are connected?
:D
#9 User is offline   Ghostwalker Icon
Posted 20 June 2004 - 10:58 AM
No but if you search samurize.com there is an msn plugin that will do that.
