Aqua-Soft Forums: [help] Avedesk - Jet Black Hd And Documents - Aqua-Soft Forums
[help] Avedesk - Jet Black Hd And Documents Rate Topic: -----
#1 User is offline   risingsun Icon
Posted 12 May 2004 - 06:10 AM
Hi I just downloaded Avedesk and I was wondering how you change the Labels and Icon
to look like the one in Arcanthur's screenshot....
http://www.aqua-soft...showtopic=14173
Thanks.
Please tag your threads. This is a [help] thread.
The Topic Has Been Tagged
// Seph
#2 User is offline   lostspyder Icon
Posted 12 May 2004 - 06:52 AM
have you tried the desklet settings dialog..... <_<
#3 User is offline   risingsun Icon
Posted 12 May 2004 - 07:27 AM
Yes, I can get to change the Icon using Desktet/Properties...
But I want to change the label part of it to look like screenie above...
:canadian:
#4 User is offline   lostspyder Icon
Posted 12 May 2004 - 07:30 AM
Go to the "label" tab and where it says background, select the jet black lable you downloaded
#5 User is offline   risingsun Icon
Posted 12 May 2004 - 07:37 AM
Sorry, but I don't see "Labels" tab in the Properties menu...
Attached File(s)
  • Attached File  2.JPG (24.36K)
#6 User is offline   Seph Icon
Posted 12 May 2004 - 07:53 AM
Etiquete = label in french... am i wrong?
#7 User is offline   risingsun Icon
Posted 12 May 2004 - 08:11 AM
lol, je ne sais pas beaucoup de francais...
anyways, i was looking at the wrong desklet, i should've used Mountchecker instead of HD...
I got it to work but for some reason I can't change my Label Description:
eg. currently my label reads: c (main)
i want it to read: My Drive
any help would be welcome...merci :rock:
#8 User is offline   AndreasV Icon
Posted 12 May 2004 - 10:03 AM
Use PowderMount which you can get at www.dockex.com
:smartass:
