Aqua-Soft Forums: [help] Shortcut Docklet And Desktop... - Aqua-Soft Forums
[help] Shortcut Docklet And Desktop... Rate Topic: -----
#1 User is offline   d-shade Icon
Posted 24 February 2004 - 02:53 AM
ok this is what im trying to do
im trying to get the shortcut docklet to goto my desktop folder
C:\Documents and Settings\user\Desktop
but when it does instead of showing just the contents in the folder it shows everything on the desktop even my computer and such.. its kinda weird..
the shortcut path on the docklet is
when i goto that folder by clicking on it it goes fine
and it also works fine if i copy paste into the address bar..
any solutions???
[edit]
opps i meant desklet..
#2 User is offline   Fujita Icon
Posted 24 February 2004 - 05:51 AM
You use this method.
Path:
C:\WINDOWS\explorer.exe
Parameters:
shell:DesktopFolder
#3 User is offline   kerin Icon
Posted 24 February 2004 - 12:36 PM
you can also use the "syscmd" docklet for OD, it's very usefull
you got it on DockEx
