[help] Need Help With Od Weathermonitor...
448
11-August 03
Posted 13 February 2004 - 10:50 AM
Hi.
I have WeatherDocklet.dll (d\l from customize) but when who to setup it? its show a temp and a question image (AveDesk default) as a weather state...
I have an icons for different conditions but I don't know how to set it up...
406
22-October 03
Posted 13 February 2004 - 03:18 PM
ok for the weather docklet , you may have this tree
..\docklets\weather\ => your DLL file
..\docklets\weather\icons => all your icons files (00.PNG->47.PNG)
if you have it, it should work
if not, try to reinstall the docklet, everything is set up (the tree) to work so don't touch the files after extracting, just copy them
448
11-August 03
Posted 16 February 2004 - 08:29 AM
Thanks!
448
11-August 03
Posted 16 February 2004 - 05:10 PM
Not good
Reinstall the docklet and got this error when try to setup location for weather docklet...
Maybe somebody can give me a link for good desklet version?
Maybe mine is bad...
406
22-October 03
Posted 16 February 2004 - 10:55 PM
you got it on wincustomize.com
check out your AveDesk version to
