swamyveera Posted October 10, 2008 Report Share Posted October 10, 2008 Hi thereI installed the new rk launchar, looks awesome with the leapord style docks.I was trying to have a stackicon in my launcher with links to other programs. I managed to do it by adding a stackdoklet and pointing it to a folder with all the links, but how do i change the icons for these links, i could'nt find a way to do this. Can somebody guide me with this.ThanksVeeru Link to comment
AndrewYY Posted October 22, 2008 Report Share Posted October 22, 2008 Reshacker, maybe? Of course, this means changing the icon for the original exe, but you should be fine with that.http://www.angusj.com/resourcehacker/ Link to comment
Ghostwalker Posted October 22, 2008 Report Share Posted October 22, 2008 If those are all shortcut links just go to each link and right click go to properties and change the icon. If they are exe file use a shortcut instead. Link to comment
kycoalminer Posted November 24, 2008 Report Share Posted November 24, 2008 I have the same problem. when i make a new stack docklet i cannot change the icon for it.http://i135.photobucket.com/albums/q122/bo...tackdocklet.jpgthat is what it shows but when i but when i browse and place an icon nothing happens. any help please. Link to comment
brishu Posted December 18, 2008 Report Share Posted December 18, 2008 hi, yes that is a problem with RK launcher .... happenned to me with Kk menu ..... the solution SHOULD work with Stack docklet too ... go to Itemlist.conf (should open in notepad(or default text-editor)) scroll down until you see the stack docklet entry; should be a name entry in one of the [RKDockItem] s .... go to one that has "iconFilename" (q/o quotes in it ... ) and change it from C:/your/icons/path.whatever to C:youriconspath.whatever ... SHOULD work ..... Link to comment
