schmrom Posted June 4, 2008 Report Share Posted June 4, 2008 I was bored again and I needed a simple tool to preserve a edge on screen, so I made one.Features- Adjustable edge and size- Trayicon- SettingsdialogRequirements- Windows XP or Windows Vista- .NET Framework 3.5Initial settings- Edge: Bottom- Size: 32pxChangelog2008-09-02 09:21 AM - v2.3.0 (12)- Added a option to hide TrayIcon- Pressing Strg+Alt+B will show options dialog- Several small bugfixes- Consumes less memory2008-07-15 15:18 - v2.2.0 (5)- Double click on trayicon will now open the settings dialog- Settings dialog has now a "Quit DesktopBar2" button2008-06-16 10:05 - v2.1.0 (4)- Removed installer2008-06-15 14:01 - v2.1.0 (3)- Fixed a bug with resizing of the bar2008-06-15 13:38 - v2.0.1 (2)- Completely redone in C#- Now with setup- Added own options dialog- Fixed the problem with systemtray menu (hope so)2008-06-04 23:38 - v1.0.0- Initial ReleaseDownloadDownload v2.3.0 (12) Link to comment
stone80a Posted June 4, 2008 Report Share Posted June 4, 2008 Cool little utility. I always want to leave some space from my taskbar (on top) to the program I am running, so I see a small part of the desktop behind. Many thanks, schmrom. Link to comment
schmrom Posted June 4, 2008 Author Report Share Posted June 4, 2008 Cool little utility. I always want to leave some space from my taskbar (on top) to the program I am running, so I see a small part of the desktop behind. Many thanks, schmrom. Thanks for the comment You mean on more than one side? Link to comment
DarkFire Posted June 5, 2008 Report Share Posted June 5, 2008 A screen plz?But it sounds nice... Link to comment
Davordg Posted June 5, 2008 Report Share Posted June 5, 2008 rg !! but ..windows SP3 -miss..... Link to comment
Sranshaft Posted June 5, 2008 Report Share Posted June 5, 2008 Bug report: Whenever I try to right-click the system tray icon to get at the menu it disappears after a second or two. Makes it kind of hard to get at the options. Had to kill it manually from the control panel. Link to comment
kftrainer Posted June 5, 2008 Report Share Posted June 5, 2008 yes I had the same problems with right click on the tray icon and where is the default postion screen wise Link to comment
lostfly Posted June 5, 2008 Report Share Posted June 5, 2008 oh.that is cool!but when I killed the process,the edge of screen still preserved,so ,why need keep the process runing? run it once, and quit ,it's work too,:-) Link to comment
Björn Posted June 5, 2008 Report Share Posted June 5, 2008 Bug report: Whenever I try to right-click the system tray icon to get at the menu it disappears after a second or two. Makes it kind of hard to get at the options. Had to kill it manually from the control panel.Yes that one.What does the app actually do? Link to comment
ethereal Posted June 5, 2008 Report Share Posted June 5, 2008 right click problem here as well> Buddy..not recommended to dl Link to comment
kftrainer Posted June 8, 2008 Report Share Posted June 8, 2008 Are there any updates or builds that follow to address these issues ? Link to comment
schmrom Posted June 8, 2008 Author Report Share Posted June 8, 2008 Are there any updates or builds that follow to address these issues ?Yes, I am working on it. Link to comment
kftrainer Posted June 8, 2008 Report Share Posted June 8, 2008 thanks I will be waiting Link to comment
schmrom Posted June 8, 2008 Author Report Share Posted June 8, 2008 I just need someone to test on XP, because I only have Vista Link to comment
jonatasjam Posted June 14, 2008 Report Share Posted June 14, 2008 Bug report: Whenever I try to right-click the system tray icon to get at the menu it disappears after a second or two. Makes it kind of hard to get at the options. Had to kill it manually from the control panel.I had the same problem too. Link to comment
schmrom Posted June 15, 2008 Author Report Share Posted June 15, 2008 Okay, I pushed a update an I've redone it in C# and hopefully fixed the bug!Edit: Found another bug, fixed it Link to comment
kftrainer Posted June 15, 2008 Report Share Posted June 15, 2008 I am having problems with the downloaded application - I did not know that I needed to download Microsoft .Net 3.5 and then it did not even give me the application I got a error message that it was unable to download I know that i was taking a chance since it has not been tested for XP so are you working on a version for XP ? Link to comment
Sranshaft Posted June 16, 2008 Report Share Posted June 16, 2008 Ouch. German setup window? Thank god for my 5 years of it in school...hehe Still though, I have .net 3.5 installed and yet it complained about it (I think, my translation may be rusty). Why include an installer for something so little? Can we possibly get a standalone zip file? Link to comment
schmrom Posted June 16, 2008 Author Report Share Posted June 16, 2008 Ouch. German setup window? Thank god for my 5 years of it in school...hehe Still though, I have .net 3.5 installed and yet it complained about it (I think, my translation may be rusty). Why include an installer for something so little? Can we possibly get a standalone zip file? Sry, forget that I have a german Visual Studio Uploaded a standalone, link is in first post. Link to comment
kftrainer Posted June 16, 2008 Report Share Posted June 16, 2008 I just downloaded the new version and the right click menu still does not work correctly it times out with 2 sec. Link to comment
kftrainer Posted June 16, 2008 Report Share Posted June 16, 2008 I am on Windows XP btw sp3 rc Link to comment
schmrom Posted June 16, 2008 Author Report Share Posted June 16, 2008 I just downloaded the new version and the right click menu still does not work correctly it times out with 2 sec.Have you got the newest .NET Framework? If yes I will make a workaround... Link to comment
kftrainer Posted June 16, 2008 Report Share Posted June 16, 2008 Yes I have the .net version 3.5 it was downloaded and installed automatically with your last version with the installer. The Microsoft .net installed but then there were problems with the main application -giving me a error message that it could not download the Desktop bar Link to comment
schmrom Posted July 15, 2008 Author Report Share Posted July 15, 2008 Small update to version 2.2.0 (5). Changes can be found in first post. Link to comment
idsos00 Posted July 18, 2008 Report Share Posted July 18, 2008 I can't see anything which i click the icon???Is that my computer problem???I only can see the tray icon.I use the Windows XP or Vista(Eng.) are both doesn't work Link to comment
