RunMe 0.9 (Application Launcher)
RunMe: application launcher for windows.
Please backup "1.xml" to save your old links!
0.9.2
-In new version:
-I've rewrited building of links from folder algorithm. Faster, less RAM.
-SlideIn and SlideOut algorithms rewritten.
Language engine working now, all elements translated (English and Russian languages included)
-Added Vista blur (only in Aquarel [Dark Blue] theme while, for example)
-Preview for images (in context menu)
0.9
I will not write much about new features, I only tell that if I not release it now - I not release it never ;)
-Auto width for menus
-New menu item "context menu" (for file and folder)
-Option "as vista menu" for Run box item (fast searching, check Indexing tab in properties)
-Weather forecast (on click while ;))
Note: please download weather icons and place it in RunMe folder (for ex. here).
-Option "as menu" for folders:
Vista blur and new image preview in context menu:
Download RunMe v0.9.2.1
Mirror
Latest EXE: http://windocks.narod.ru/runme0.9.2.6u_exe.zip)
  • Replies 178
Posted Images
I want to add My Network Place as a menu how can I do that?
Nice simple theme on previous screenshot! :)
You can add folders as menu only like c:folder,
but I think you can make so: "New group" and links in it from your network places (something like this: computername on Object field of item properties)
Hope this helps :)
Ghostwalker,
if you use dock then you can try this:
http://ksoft.nm.ru/runme0.9.1exe.zip
it's an exe only (v0.9.1). If you make link to runme.exe in dock and will use "1.xml" as parameter,
this be will like kkmenu (not docklet). So if you made XMLs for various groups (program, documents etc),
you will have several menus in dock.
On RunMe icon, I can upload large png, but it seems to me that icon of launcher in launcher is not so useful :)
Hey KSoft,
1st your Tool is awesome, i really love it ^^
I found a Bug, i'll try to explain, but my english is not very well^^
If the Option "Hide RunMe Completely" is activated, the "Hidden" RunMe shows and hides itself every X ms. It is hard to explain ^^
Im using WinXP SP2
And then i've a Question to the Weather plugin, how can i select my Town, i dont know how^^
Greets from Germany
EugenE
Hey KSoft,
Im using WinXP SP2
Greets from Germany
EugenE
Thank You, EugenE, I will try to correct this bug,
I'm glad that RunMe helps organize Your links :)
For weather:
1)Open http://www.weather.com/ in browser
2)Search town (edit box with Go button)
3)Choose your town in found list
4)Now address in browser like this:
http://www.weather.com/outlook/travel/busi...rom=search_city
So for Berlin, for example, code GMXX0007.
This code various for other towns, use this code in Settings->Advanced->Weather group box
:) Oh what a beautiful program !!!!! Thanks a lot !
ernest33
PS : Do you have a template to make a french translation please (i saw you've prepared something about Language :-) ).
PS : Do you think it will be possible to have a popup menu for "Control Panel" (by example) ?
ernest33
Thank You, Ernest33! :)
Example of language English file here: http://ksoft.nm.ru/rm/English.ini
But unfortunately not all strings translated yet, so I think I should make normal system for translation at first. But thanks for interest! :)
(for language files it's needed to create "Languages" folder and place ini file here).
On Control Panel, it's possible now only make popup menu and add System items there (in Properties of item, Type=System).
Edited:
or, Ernest33, You can place links to all Control Panel items in separate folder (Open CP, select all items and drag'n'drop to folder) and make DiscOrFolder item with "As Popup Menu" parameter and it will be popup menu with all Control Panel items.
Hi,KSoft,I'm just wondering if you could make it pop up like the Object Dock Plus ?
Please see the attachment,thank's
Oh, it's really horizontal position of Object dock with tabs?
It's absolutely another idea (horizontal position of items) and I think it must be new program then, with new system of skining :(
