Carlospr Posted August 25, 2007 Report Share Posted August 25, 2007 CD Art Display 1.0 (24Aug2007) CD Art Display is a skinnable application that shows the now playing song cover on your desktop. It's an addon that fully works with AlbumPlayer, Helium Music Manager, iTunes, Winamp, Windows Media Player, MediaMonkey and partially supports qmp, MP3Toys, musikCube and foobar2000 (Winamp API Emulator plugin). History note The first CD Art Display alpha was released in 25Feb2005. It was just for Winamp and that's why it was named Winamp CD Case (WCC) back then. The case was just a bmp file and folder.jpg was the only option for a local cover. After more than 2 years CD Art Display 1.0 is a bit better, stable and supports more players. That's all. Today, 24Aug2007, is the official CD Art Display 1.0 release!! What's new? - New engine: mirror, rotation, shear, round corners, blend and cover transition - New toolbar with repeat and shuffle support - New player volume - New Panel and extended panel feature - New text soft shadow and scrolling features - New seek/progress bar feature - New mixed progress bar - New lyrics viewer - New rating and custom text rating - New skin appearance settings - New skin Styles - New context menu - New Options and Skin Editor instead Control Panel - Added Helium player support - Improved stability - Fixed bugs Requirements - Windows Vista or Windows XP - Visual Basic run-time 6 SP6 - Visual Basic run-time 5 (just if you're using Windows Vista) Download Full setup: cad1setup.zip - 1.03MB Main executable (*): cad1.zip - 0.76MB (*) copy "Default" skin into CAD "Skins" subfolder Skins Check Skin Gallery at CD Art Display forum so you can test all new features. Screenshot Acknowledgment I'd like to thank you all for support CAD in any way. Specially I'd like to thank OtisBee for all his ideas and help regarding all new features. Link to comment
davidsword Posted August 25, 2007 Report Share Posted August 25, 2007 I've been waiting for this! Link to comment
delta909 Posted August 25, 2007 Report Share Posted August 25, 2007 Carlos thank you very much for this great app ... Link to comment
idawn Posted August 25, 2007 Report Share Posted August 25, 2007 Wonderful... thks for the great finish Link to comment
nessa Posted August 25, 2007 Report Share Posted August 25, 2007 Yes, I've been waiting for the final version to try this. Thanks! Link to comment
fattieslim Posted August 25, 2007 Report Share Posted August 25, 2007 Love the program, just one thing. It doesn't seem to show special characters correctly :[ If this gets fixed I'll be using the program all the time Link to comment
TuxmanXP Posted August 25, 2007 Report Share Posted August 25, 2007 Great, I think I'll drop that odd Winamp cover plugin for this... thanks. Link to comment
Sranshaft Posted August 25, 2007 Report Share Posted August 25, 2007 Great stuff mate. This is truly excellent software. Thank you very much for the time and effort you have put into this and congratulations on the 1.0 release. Link to comment
Lykos Posted August 28, 2007 Report Share Posted August 28, 2007 This is great. Thank you for your dedication to this program. Link to comment
Carlospr Posted August 29, 2007 Author Report Share Posted August 29, 2007 Thank you all for your kind words! They are an impulse to keep the project alive! Link to comment
detee Posted August 31, 2007 Report Share Posted August 31, 2007 Great program! Thank you for sharing it with us. Using it with WInamp. Link to comment
Guest Di7ra Posted September 6, 2007 Report Share Posted September 6, 2007 That's great work! Thanks. Especially good for Foobar2k because AveTunes doesn't support player. Link to comment
Carlospr Posted September 6, 2007 Author Report Share Posted September 6, 2007 Thanks detee. By the way Di7ra there's a CAD user making a foobar2000 component that will give a full integration with CAD. Link to comment
chermany4ever Posted January 4, 2008 Report Share Posted January 4, 2008 Great work Carlos! Near to perfection! This app is totally enjoyable! :mad: I use foobar2000 so I'm specially glad about the new component coming. :cool: Link to comment
Carlospr Posted January 5, 2008 Author Report Share Posted January 5, 2008 Thanks chermany4ever!The new component is ready and working great!Soon CAD 2.0 beta will be available for all users:http://www.cdartdisplay.com/forum/index.php Link to comment
BabboNatale Posted January 5, 2008 Report Share Posted January 5, 2008 I already know it and I like it so much.Xion support is a feature of 2.0? Link to comment
MacRulesWorld Posted January 5, 2008 Report Share Posted January 5, 2008 amazing! One thing can i save the downloaded lyrics to my itunes lyrics section of each song, if not any program recomendations? Link to comment
Carlospr Posted January 5, 2008 Author Report Share Posted January 5, 2008 I already know it and I like it so much.Xion support is a feature of 2.0?Not planned yet.amazing! One thing can i save the downloaded lyrics to my itunes lyrics section of each song, if not any program recomendations?I can take a look if it's possible to do. Link to comment
NetOperator Wibby Posted January 10, 2008 Report Share Posted January 10, 2008 first, i would like to say thank you for making this app. second, i would like to ask: is the plugin for foobar done yet? does the developer need beta testers? Link to comment
Carlospr Posted January 11, 2008 Author Report Share Posted January 11, 2008 Yes the new foobar2000 component is ready thanks to eyebex!A public beta of CAD 2.0 will be available soon (I hope in February).I'm still waiting for some translations and I still have small issues to fix. Link to comment
NetOperator Wibby Posted January 11, 2008 Report Share Posted January 11, 2008 haha, that's great news! and to think, i just downloaded CAD a couple days ago. i can't wait to test out the beta. thanks for your continued development! Link to comment
matakucoklat Posted April 29, 2009 Report Share Posted April 29, 2009 i got it...thankz dude Link to comment
