davidsword Posted March 8, 2007 Report Share Posted March 8, 2007 Hey I just download a very nice boot skin from devuantart, It came with .bootskin file and no instructions. How do I instal this???//Thread Moved. -NC Link to comment
icreativity Posted March 8, 2007 Report Share Posted March 8, 2007 you just need Stardock's BootSkin app. you can get it here.all this application actually does is recompiling the .bootskin zipped file into a valid kernel executable (just like ntoskrnl.exe).apply the screen, then look into system32 folder (after arranging files by modified) and you should find it there, right at the end.you can keep it (in this native format) for later use.in addition, you can apply a kernel file easily, just by editing the boot.ini system file (post here if you wanna know more).cheers,costas Link to comment
Bebi_Bulma Posted March 8, 2007 Report Share Posted March 8, 2007 Bootskin basics - keep in mind it doesn't work with all BIOS, and if it doesn't work there are alternative versions you can try, but if none of those work you're basically S.O.L. Link to comment
