revolutionized55 Posted October 12, 2006 Report Share Posted October 12, 2006 hey every1, im new to Aqua Soft but it has helped me a great deal in the windows-to-mac transformation. everything so far looks excellent, but there's 2 things i was wondering some1 here could help me with: 1.)i read a post about putting your minimize/maximize/exit buttons on the left side, and it involves hacking a "DLL" file. i was wondering if you could tell me which DLL file i need to hack, and how to hack it. and 2.)does any1 know where i can get the genie effect??! i've been looking for ever lol. the genie effect thing isnt as important as the .dll hack thing. you can contact me at my email if it's a long explanation, or just post it here. peace ppl !! Link to comment
flyakite Posted October 12, 2006 Report Share Posted October 12, 2006 1. You can't hack a dll file and get the glyphs on the left. You have to use 3rd party software like WindowBlinds, and a skin that is designed for WindowBlinds with the glyphs on the left. Look around, you can find plenty.2. http://home.cogeco.ca/~rklauncher/ On the right, towards the bottom "Aladdin's Lamp". It only works for RK Launcher obviously. Link to comment
revolutionized55 Posted October 12, 2006 Author Report Share Posted October 12, 2006 unfortunately, i have aqua dock, so will that be a problem? Link to comment
duyvan82 Posted October 12, 2006 Report Share Posted October 12, 2006 yes it won't work with any other dock... why don't you give RKLauncher a shot??? It's worthit Link to comment
revolutionized55 Posted October 12, 2006 Author Report Share Posted October 12, 2006 yea thx a lot man! RKdock is a lot btr, and i have the original mac icons so its looks btr. now if i could just get a skin that puts the glyphs on the left side without having to download a giant 70mb program like windowsblins (which i don't use). so if any1 knows any way i can get the glyphs on the left side without windowblinds, give me a shout out peace out Link to comment
wizard Posted October 12, 2006 Report Share Posted October 12, 2006 yes it won't work with any other dock... why don't you give RKLauncher a shot??? It's worthit Or at least, not a rippoff of Y'z. Give Mr. Yamaguchi your respect and use the real thing at least Link to comment
revolutionized55 Posted October 12, 2006 Author Report Share Posted October 12, 2006 i just installed RKlauncher and the genie effect, but the genie effect won't work. what's the problem? Link to comment
Bebi_Bulma Posted October 13, 2006 Report Share Posted October 13, 2006 I don't think there is a way to move the glyphs to the left without windowblinds. I use it and have absolutely no complaints. And I'm not sure where you are getting the idea that it's some "giant" program at 70mb, it's only 11.69mb. cnet Download.com link Link to comment
revolutionized55 Posted October 14, 2006 Author Report Share Posted October 14, 2006 thx guys, a lot of help. so now that i downloaded windowsblinds, which theme that looks lyk mac os x is the best one to use that will put the glyphs on the left? Link to comment
Bebi_Bulma Posted October 14, 2006 Report Share Posted October 14, 2006 Well, choosing the "best" one is simply a matter of preference. Tiger 2 by KoL is a pretty good one. Link to comment
revolutionized55 Posted October 14, 2006 Author Report Share Posted October 14, 2006 ok i downloaded the tiger os x, but it only displays the normal window buttons and keeps them on the right. how can i fix it? Link to comment
Bebi_Bulma Posted October 14, 2006 Report Share Posted October 14, 2006 I'm not sure, I believe that skin only has the glyphs on the left side, not the right. Screenshot? Link to comment
revolutionized55 Posted October 14, 2006 Author Report Share Posted October 14, 2006 ok thx man Link to comment
darkrunejr Posted November 12, 2008 Report Share Posted November 12, 2008 hey u guys im new but i heard u can get sum files to hack GunZ The Dual at www.ijji.com , can sum1 help me? Link to comment
holo13x Posted November 20, 2008 Report Share Posted November 20, 2008 ok i heard u neded a file to put ur close buttons on the lesft u can get it here http://software.emule.com/leftsider-1-03/ Link to comment
