mayamaniac Posted March 28, 2006 Report Share Posted March 28, 2006 stupid question, but how do I add these? Of course RK wouldn't let me drag these icons into it. I made a shortcut of My Computer, I dragged it in and it works, but when I click on the icon, My Computer doesn't open up, nothing happens. Help please.oh also, dont want to start another thread, but is there a way to keep items both on RK and the taskbar when they are minimized? Currently when I minimize to RK, the item is removed from the taskbar. Link to comment
aleph Posted March 29, 2006 Report Share Posted March 29, 2006 While for avedesk- I think the principle in this message will be the same. The important thing is the string in the parameters field I thinkhttp://www.aqua-soft.org/board/showpost.ph...437&postcount=2 Link to comment
nightcrawler1089 Posted March 29, 2006 Report Share Posted March 29, 2006 The answer to your second question is no. -NC Link to comment
Austin123 Posted March 29, 2006 Report Share Posted March 29, 2006 do you have the latest build of RK, just tested it and it works fine for me? OoIf it doesn't work fallow this procedure: right-click>select dock item properties>change the link to this=::{20D04FE0-3AEA-1069-A2D8-08002B30309D} Link to comment
vitasg Posted March 29, 2006 Report Share Posted March 29, 2006 If by "My Computer", you mean an Explorer link that opens to My Computer when you click on it from the dock, go to C:/Prgram Files/Accessories and drag the Explorer icon there to your dock. Link to comment
ssmith Posted March 29, 2006 Report Share Posted March 29, 2006 The only way I could get this to work was to drag the shortcuts from the Windows Start Menu to the dock. For some reason I could not get any of the other methods to work. Link to comment
nilness Posted March 29, 2006 Report Share Posted March 29, 2006 Okay, first make a shortcut to explorer.exe and drag that into rklauncher. Then edit its Dock Item Properties, specifically, the Arguments, like so:Name: My ComputerLink: C:windowsexplorer.exeArguments: ,,::{20D04FE0-3AEA-1069-A2D8-08002B30309D}In the Arguments, that's two commas and two colon symbols. Also, you can replace the GUID with any of these common GUIDs (you can trawl through the registry clsid key for more):My Computer: {20D04FE0-3AEA-1069-A2D8-08002B30309D}Recycle Bin: {645FF040-5081-101B-9F08-00AA002F954E}Desktop: {00021400-0000-0000-C000-000000000046}Control Panel: {20D04FE0-3AEA-1069-A2D8-08002B30309D}::{21EC2020-3AEA-1069-A2DD-08002B30309D}Printers: {2227A280-3AEA-1069-A2DE-08002B30309D}Dial-up networking: {A4D92740-67CD-11CF-96F2-00AA00A11DD9}Fonts: {BD84B380-8CA2-1069-AB1D-08000948F534}Internet Explorer: {871C5380-42A0-1069-A2EA-08002B30309D}Microsoft Outlook: {00020D75-0000-0000-C000-000000000046}Network Neighborhood: {208D2C60-3AEA-1069-A2D7-08002B30309D}Inbox: {00020D76-0000-0000-C000-000000000046}Briefcase: {85BBD920-42A0-1069-A2E4-08002B30309D} Link to comment
mayamaniac Posted March 29, 2006 Author Report Share Posted March 29, 2006 The answer to your second question is no. -NC Damn, this makes the taskbar useless. I'll just hide it for now. I found a docklet that opens the Start menu, but haven't found one for the system tray. I'm not sure if I can live without the system tray from day to day work. Is there a system tray docklet?do you have the latest build of RK, just tested it and it works fine for me? OoIf it doesn't work fallow this procedure: right-click>select dock item properties>change the link to this=::{20D04FE0-3AEA-1069-A2D8-08002B30309D} Yes I have the latest build, thanks for the tip.The only way I could get this to work was to drag the shortcuts from the Windows Start Menu to the dock. For some reason I could not get any of the other methods to work. You're right, this works, it creates the shortcut and add the arguments: ::{20D04FE0-3AEA-1069-A2D8-08002B30309D} I wonder why it doesn't do so when dragged in from the desktop. Thanks for the tip. Okay, first make a shortcut to explorer.exe and drag that into rklauncher. Then edit its Dock Item Properties, specifically, the Arguments, like so: Name: My Computer Link: C:windowsexplorer.exe Arguments: ,,::{20D04FE0-3AEA-1069-A2D8-08002B30309D} In the Arguments, that's two commas and two colon symbols. Also, you can replace the GUID with any of these common GUIDs (you can trawl through the registry clsid key for more): Many thanks, very useful to know all those shortcut arguments. Link to comment
nightcrawler1089 Posted March 30, 2006 Report Share Posted March 30, 2006 Try this: http://www.wincustomize.com/viewskin.aspx?...=29&SkinID=3916-NC Link to comment
mayamaniac Posted March 30, 2006 Author Report Share Posted March 30, 2006 Try this: http://www.wincustomize.com/viewskin.aspx?...=29&SkinID=3916 -NC Thanks, but doesn't seem to work in RK. Link to comment
irefoy Posted March 30, 2006 Report Share Posted March 30, 2006 maybe this is what you are looking forhttp://quero.at/it is a Toolbar for IE and Explorer for searching and many other features.one of the feateres is that it shows the windows internal Name of a folder (the numbers manchend above) Link to comment
Cereal_killer Posted April 1, 2006 Report Share Posted April 1, 2006 With the shortcut of explorer.exe is there any way to open it in one click just as in quick launch in the taskbar?It would be faster than double-click! Link to comment
Levi- The perfectionist Posted April 1, 2006 Report Share Posted April 1, 2006 I made a shortcut of My Computer, I dragged it in and it works, but when I click on the icon, My Computer doesn't open up, nothing happens. Help please.oh also, dont want to start another thread, but is there a way to keep items both on RK and the taskbar when they are minimized? Currently when I minimize to RK, the item is removed from the taskbar.Dont drag shortcuts into the dock (dock makes shortcuts when you drag them in, but making a double shortcut wont work); instead drag "my computer" itself into the dock. I have done this and it works. If you need to find 'my computer' (encase you've lost the original icon); open explorer and in the address bar click the down arrow and select desktop in the window- "my computer" will appear, drag into dock (DO NOT make a shortcut first).There is a way to stop minimising to the dock and instead minimise to the taskbar, but there is currently no way to minimise to both taskbar and dock. To minimise to taskbar only; right-click on a blank part of the dock and select "settings", click the bahaviour tab, then de-tick "minimise to rk launcher" tick box and close off the options.hope that helps and that im not stating the obvious. Link to comment
ssmith Posted April 3, 2006 Report Share Posted April 3, 2006 If you need to find 'my computer' (encase you've lost the original icon); open explorer and in the address bar click the down arrow and select desktop in the window- "my computer" will appear, drag into dock (DO NOT make a shortcut first).When I try this with the "My Computer" icon from the Desktop folder in Explorer, all I ever get is the cursor changing to "Unavailable" when I get to the dock. I could only get My Computer from the Start Menu to work as drag and drop. Interestingly enough, My Documents works from Explorer, but My Network Places, My Computer and the Recycle Bin do not. Link to comment
lane32x Posted May 5, 2006 Report Share Posted May 5, 2006 Solution:RK Launcher .41 would not let me drag and drop any windows desktop 'Special' Icons to it (e.g. My Computer, My Bluetooth Places, etc.)The primary reason I use RK is to get rid of desktop icons, but .40 wasn't responsive enough and .41 didn't allow these specials to be drag-and-dropped. what to do, what to do?So I opened RK Launcher .40 beta again, Enabled 'My Computer' on my desktop and dragged the icon to the dock. (can you drag 'special' icons to your dock if you use .4 beta?)then i installed the .41 nightly (build 246) and kept my itemlist.conf here's what's in my itemlist.conf[RKDockItem]type = shortcutname = My Computerlink = ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}show = normal[RKDockItem]type = shortcutname = My Bluetooth Placeslink = ::{6AF09EC9-B429-11D4-A1FB-0090960218CB}show = normal(in otherwords...you can use the 'arguments' trick like they said up above, but here's the link for bluetooth in case anyone needs it) Link to comment
