Unbeliever Posted April 19, 2004 Report Share Posted April 19, 2004 Nimix has released a new OD SysTray docklet on WinCustomize.It doesn`t require installation (like KkTray) so it should be light on resources.Here is Nimix' description from WinCustomize:his docklet for ObjectDock shows the icons from the Windows system tray (information area) in a docklet icon. The icons in the docklet have the same unctionality like the icons in the windows system tray. This also works if the Windows Taskbar is hidden. The ObjectDock Tray Docklet doesn't have to be installed with an install programm because it doesn't have a Tray Server application like kkkmenu.Few notes:Tray icons for programs that change state (IMs, Firewalls, etc.) don`t update with the changed state. So the icon that was on when the program started, will stay in Tray Docklet even if it has changed.I haven`t managed to make it work. It doesn`t show anything, and crashes my dock on left or right click, so use this visely. But from the comments i`ve ready @ WinCustmize, it runs smooth for most people.EnjoyNimix' SysTray Docklet Link to comment
d-shade Posted April 27, 2004 Report Share Posted April 27, 2004 i got it to work but it seems to keep producing a bunch of mbm icons.. but other then that it seems to work.. Link to comment
Nimix Posted May 28, 2006 Report Share Posted May 28, 2006 There is a new version on www.nimix13.ni.funpic.de/tray(Link fixed. -NC) Link to comment
nightcrawler1089 Posted May 28, 2006 Report Share Posted May 28, 2006 //Thread Closed.I figure you also posted it here:http://www.aqua-soft.org/board/showthread.php?t=35496-NC Link to comment
